The S Series is the basic version of Voith universal joint shafts and has been designed for small- to medium-sized drives. The connection flanges are friction flanges. In building the S universal joint shafts, we use high-strength tempered and case-hardened steels that assure the ability to withstand static and dynamic loads. The universal joint shafts have high torque capacity combined with optimal bending and torsion rigidity.
Torques with a single load MZ
Up to 35 kNm
Torques with a reversing load MDW
Up to 11 kNm
Center section
Steel
Deflection angle
Up to 35°
Rotation diameter of the joints
52 mm to 204 mm
Connections
Friction flanges
Length compensation
Telescopic (involute profile)
None (fixed-length shaft)
VOITH
voith.com/corp-en
Filed Under: Coupling Tips
