Voith universal joint shafts ensure productivity and reduce maintenance costs. The torque capacity extends beyond 20,000 kNm (14 million lbf ft). If necessary, the design layout of our universal joint shafts can be adapted to your drive and operating conditions.
Individually designed for high and maximum torques
The CH Series is the standard for high and maximum torques. CH universal joint shafts, connection components, and shaft support systems are individually built to specific requirements of your drive system. Flanges and flange yokes are available in a very wide range of designs and materials. Voith offers a complete customized drive solution from one single source
+ Torques with a single load MZ
Up to 19,440 kNm
+ Torques with a reversing load MDW
Up to 11,910 kNm
+ Center section
Steel carbon fiber-reinforced polymer (CFRP)
+ Deflection angle
Up to 15°
+ Rotation diameter of the joints
350 mm to 1,400 mm
+ Connections
- Flanges with face key
- Flanges with Hirth serrations
- Flanges with split sleeves
- Quick-release couplings
- Connection components for rolling mills (wobblers)
- Adapters
Voith
voith.com
Filed Under: Coupling Tips
