  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Voith variable speed couplings for cooling fans
By Mike Santora | May 18, 2020
Voith-variable-speed-couplingVariable Speed Coupling TurboCool
The Voith TurboCool coupling optimizes the operation of gas compressor stations with engine-driven cooling fans. This coupling reliably regulates the speed of the fans to maintain optimum cooling performance.
The advantages:
The cooling system does not freeze up and does not overheat. This increases availability to the compressor station.
The cooling system requires less power. The increase of gas production is possible with saved power.
Lower cooling capacity means lower CO2 emissions and lower fan noise. Environmental pollution is reduced.
TurboCool transmits power hydrodynamically, this means through moving fluid. Power transmission is thus wear-free. Connection to a three-phase supply is not necessary. Thus, the coupling is directly applicable to remote compressor stations that are not connected to the power grid. The coupling can be integrated into new as well as existing systems. It has power from 45 to 110 kW.
Voith
voith.com
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
