VRX Rotary Vane Actuators from Tolomatic
By Design World Staff | January 28, 2009
MINNEAPOLIS, MN ‚– New VRX rotary vane actuators from Tolomatic deliver up to 484 inch-pounds (54.7 Newton-meters) of torque at 100 psi (6.9 Bar) and can withstand high axial loads of up to 23 pounds (102 Newtons). These pneumatically operated rotary vane actuators are designed for use in material handling, part feeding and clamping, pick and place operations, cutting and many other industrial automation applications requiring rotary motion.
VRX actuators are available in bore sizes of 1 inch (25.4 mm), 1.75 inches (44.45 mm) and 2.5 inches (63.5 mm). Each model is available with single or double vanes on a corrosion-resistant single- or double-ended shaft. The single-vane models rotate to 280 degrees and produce up to 242 inch-pounds (27.3 Newton-meters) of torque. The double-vane models rotate to 100 degrees and produce up to 484 inch-pounds (54.7 Newton-meters) of torque.
The VRX series also features self-lubricating Highly Saturated Nitrile (HSN) seals that deliver three to five times the service life of Buna-N. In addition, the seals are molded directly onto the oversized vanes and rotor shaft to ensure a tight fit. All models have corrosion-resistant bodies and heads that are anodized to ensure long life and low breakaway. VRX models with double-ended shafts and bores of 1.75 inches (44.45 mm) or 2.5 inches (63.5 mm) are available with an infinitely adjustable stop option. This mechanism allows users to dial in rotational stops of less than the 100 or 280 degrees of standard rotation.
www.tolomatic.com
Filed Under: Actuators, Motion control • motor controls
