VTMF Series: Vertical Rotary Indexers for Heavy-Duty Applications
By Sponsored content | January 1, 2025
Motion Index Drives introduces the VTMF series, a range of rotary indexers meticulously designed for vertical mounting orientations. Ideal for heavy automated robotic weld cells, robotic inspection cells, or robotic assembly applications, the VTMF series stands as Motion Index Drives’ flagship for precision and adaptability.
VTMF 1010
Key Features of the VTMF Series
  • Vertical Mounting Expertise: Engineered with a focus on vertical applications, the VTMF series is tailored for seamless integration into heavy-duty robotic setups. Standard trunnion bases are available to easily incorporate the VTMF indexing table into a customer provided risers. Additional sealing ensures optimum performance in vertically mounted configurations.
  • Safety Integration: The VTMF series goes beyond standard offerings by providing additional mounting surfaces for safety lockout devices. This feature is particularly crucial for maintaining safety protocols in vertically mounted positioning applications.
  • Backlash-Free Operation: Leveraging advanced cam and cam follower technology, the VTMF rotary indexer guarantees extremely high accuracy and repeatability. Experience a backlash-free operation that sets new standards in precision.
  • Bearing Excellence: The standard VTMF1010 and VTMF2010 models feature a 4-point contact bearings assembly on the rotating flange’s outer diameter, providing rigidity and supporting specified loads without requiring additional bearing support. The VTMF3010 takes it a step further, incorporating additional bearing support to handle substantial static torque and tilting moments, making it ideal for demanding applications like Sky Hook weld positioning.
  • Versatile Compatibility: Serving as an auxiliary axis to all major robot brands, the VTMF series offers unparalleled versatility. Motion Index Drives engineers can precisely size the trunnion indexer and recommend the ideal auxiliary axis motor for any application.
Impressive Load Handling: The VTMF1010 can handle swing diameters of approximately 2800 mm and over 2000 kg, while the robust VTMF3010 effortlessly manages swing diameters of 4500 mm and several tons. These capacities make the VTMF series a powerful choice for a wide range of applications.
Custom Sizing Support
Sizing the right trunnion indexer involves various considerations such as mass moment of inertia, center of gravity of the total load, speed of rotation, stop time during light screen violations, and the type of motor used. Motion Index Drives technicians are ready to assist in tailoring the perfect solution for each unique application.
Conclusion
With over fifty years of experience, Motion Index Drives offers precision indexing equipment tailored to diverse applications. The company’s expertise in engineering and innovation ensures reliable, cost-effective, and durable solutions for modern manufacturing needs. Whether standard or custom-adapted, MID delivers superior indexing systems to meet unique customer requirements, setting the benchmark in motion control technology.
Sponsored content by Motion Index Drives
Filed Under: Rotary, Linear and Multi-Axis Indexing Solutions
Tagged With: motionindexdrives
