Torsional flexible coupling equipped with elastic element working in compression. Suitable for motion reversals and multidirectional flexibility.
Technical Data
Torque Range TKN [kNm]0.025 kNm – 48.6 kNm
Speed range [1/min]1200 RPM – 12500 RPM
Application
High-Speed Shaft of machinery driven by electric motors.
Efficiency
Allows for compensating axial, radial, and angular misalignments
Limited maintenance required
Protects the drivetrain from shock loads
Tailor-made solutions
Modular design with high customization degree possibilities
Radial removability of the coupling without having to move the connected machinery
Possibility of integrating braking discs or pulleys within the coupling
Design
Available in different designs (G/GSN/GBN) – to satisfy the requirements of even the most restricted applications
Reverse functionality
Compact design
Vulkan
www.vulkan.com/en/products/detail/flexomax-g
Filed Under: Coupling Tips
