WAGO 2061 Series SMD PCB Terminal Block with Pushbuttons
By WDD Staff | July 8, 2014
WAGO (Germantown, WI) has introduced the new 2061 Series SMD PCB Terminal Blocks with Pushbuttons, ideal for PCB-based LED lighting and industrial electronics. The perfect connection for incoming power to an LED driver, or for higher power LED modules, the 2061 Series accommodates a broad range of conductors, making it highly versatile for worldwide applications. The surface-mount terminal block features:
  • CAGE CLAMPS connection technology, which allows for PUSHWIRE connection of solid or pre-bonded conductors.
  • Easy handling via side-entry wiring and top-of-unit actuation.
  • 6 mm pin spacing with a 10A current rating and up to 16 AWG, as well as a rated voltage of up to 600V (1P).
For more information, visit www.wago.com.
Filed Under: M2M (machine to machine), Terminal blocks
