WAGO ECO Ethernet Coupler
By Dave Miyares | December 11, 2009
WAGO Corporation’s new 750-352 ECO Ethernet Fieldbus Coupler enables the transition from centralized PAC/PLCs to flexible, decentralized networks. The cost-effective ECO Coupler supports prominent protocols such as MODBUS TCP/IP and EtherNet I/P, and accommodates 64 I/O modules. Ideal for applications with medium I/O counts, the 750-352 allows integrators to reduce costs via economical distributive controls.
The DIN-rail mount, UL listed ECO Coupler ensures reliable data transmission and high-speed communication via 10/100 Mbit/s Ethernet port. The ECO Coupler’s compatibility with the 300+ analog, digital and specialty modules within the WAGO-I/O-SYSTEM provides customization of distributive control applications. CAGE CLAMP® Spring Pressure Connection Technology ensures all terminations are fast, easy and maintenance-free.
The ECO Coupler can also expand the performance and usability of Allen-Bradley® RSLogix™ 5000 systems with WAGO’s free Add-On Instructions. The downloadable Add-On instructions easily integrate WAGO-I/O-SYSTEM specialty functions. Visit www.wago.us/addon, select applicable instruction(s), download and insert into program.
WAGO Corporation
www.wago.us
Filed Under: Networks • connectivity • fieldbuses, PLCs + PACs
Tagged With: WAGO
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
