WAGO Corporation has added six Dedicated Signal Conditioners to its JUMPFLEX® 857 Series Signal Conditioner and Relay family. The value-oriented Dedicated Signal Conditioners (DSCs) support focused applications requiring conversion, isolation and/or amplification of just one signal type. Although the DSCs feature hallmark JUMPFLEX® traits, including benchmark-setting 6mm housing, they do not employ an on-unit DIP switch for signal conversion. This reduces upfront costs and streamlines commissioning.
Panel- and machine-builders utilizing a PLC, VFD or controls with a specific analog input may not require the flexibility of signal configuration. Within these often price-sensitive applications, the DSCs eliminate the need for grafting additional I/O to a PLC or an additional interface card to a VFD.
To ensure safety and reliability, the DIN-rail mount DSCs provide three-way isolation (2.5kV) and utilize CAGE CLAMP®S Spring Pressure Connection Technology. All DSCs provide the market’s widest extended operating temperature range of -25°C to +70°C, and carry approvals including UL/cUL, ULex, CE and GL.
WAGO Corporation
www.wago.us
Filed Under: I/O modules, Signal analyzers, Relays, PLCs + PACs
