GERMANTOWN, WI – A new mV Signal Conditioner has joined WAGO Corporation’s JUMPFLEX line of Signal Conditioners and Relays. Engineered for industrial sensors, the 857-819 mV Signal Conditioner accepts bipolar mV inputs from -100 mV to +1000 mV, and converts to a current or voltage output. Current output available is in 4–20 mA, 0–20mA, 0–10mA and 2–10mA variants; voltage output available in 0–10V, 2–10V, 0–5V and 1–5V variants.
The 857-819 ensures safety through 3-way isolation (test voltage of 2.5kV). Beyond configuration by DIP switch, the 857-819 configures non-linear curves via WAGOFrame FDT/DTM-based software — the software also provides parameterization, start-up and field device diagnostics. The highly efficient 857-819 features transmission errors of less than 0.1% on adjusted span. CAGE CLAMP®S Spring Pressure Connection Technology provides vibration-proof and maintenance-free terminations. Additionally, CAGE CLAMP®S ensures mV Signal Conditioner terminations are temperature cycling-resistant for reliable performance in temperatures ranging from -25°C–+70°C.
The UL listed 857-819 mV Signal Conditioner shares the industry’s most compact 6mm-wide housing and common profile with the entire JUMPFLEX line. JUMPFLEX’s pluggable relays, as well as configurable and dedicated models support all signal types, and employ a flexible push-in jumpering system to eliminate redundant wiring.
WAGO
www.wago.us
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical, Signal analyzers
