WAGO Launches New Plug-In Current Transformers Product Video
By Frank Tobe | January 24, 2017
wago-pluginWAGO announces the availability of a new video featuring the Plug-in Current Transformers with CAGE CLAMP® Connection.
WAGO’s Plug-In Current Transformers measure AC currents in 230 V, 400 V and 690 V low-voltage mains. The current transformer can be loaded with up to 120% of the nominal current, allowing you to measure peak currents without damaging the transformer. The current transformers of accuracy Class 1 and Class 3 can be mounted on either round cables or current bars.
Plug-in Current transformers are equipped with the vibration-proof and maintenance-free CAGE CLAMP® connection. The output is accessible from two sides, allowing the conductor to be easily terminated even in space-restricted applications.
WAGO
www.wago.us/ctvideo
Filed Under: TECHNOLOGIES + PRODUCTS, Cables + cable management, Drives (ac) + VFDs + starters
Tagged With: WAGO
PROSTEP expands cooperation with Siemens Digital Industries Software
DRP - Line
Andantex will introduce a new planetary reducer design concept at IMTS
Custom pneumatic conveyors for unique applications
Advantech-iDAQ-3
Advantech launches iDAQ modular DAQ
