WAGO launches XTR controllers and couplers
By PR Editor | March 12, 2020
WAGO announced the addition of two new Generation 2 PFC200 PLC controllers along with two new Generation 4 Ethernet-based couplers to its XTR line of products. These devices are designed to work in the harshest environments and provide solid performance in extreme conditions.
The 750-8212/040-010 and 750-8213/040-010 XTR controllers have two configurable M12 Ethernet ports and an onboard SD card slot for additional data storage for program updates. The 750-8212/040-010 has one configurable RS232/485 port, while the 750-8213/040-010 comes equipped with one CANopen port to connect to engine parameters via J1939.
The 750-364/040-010 MODBUS TCP/UDP and 750-364/040-010 EtherNet/IP couplers each boast two M12 Ethernet ports with the rotary switches configuring the last byte of the IP addresses.
All 4 of these devices share the following features:
• -40 ⁰C to + 70 ⁰C operating temp
• Temporary condensation permitted
• 5g vibration and 25g shock
• EMC protection
• Flexible I/O system
WAGO
www.wago.com/us
Filed Under: IoT • IIoT • internet of things • Industry 4.0, Networks • connectivity • fieldbuses
Tagged With: WAGO
RF 2.0 helps engineers with radio frequency and antenna design projects
Joint consortium standardizes common “Power Consumption Management” for the shop floor
Advantech, Hivecell partnership accelerates Edge-as-a-Service for scalable AIoT
IIoT platform captures data from nearly any legacy machine to simplify the move to Industry 4.0
