WAGO picoMAX Certified for Global Design Platforms
By Stacy Combest | May 22, 2013
WAGO Corporation’s picoMAX and picoMAX eCOM Pluggable Connector Systems are certified UL 1059 and 1977, CB (Certification Body) and CSA. These international certifications confirm the all-new design’s technical properties as connector and terminal block components. picoMAX can bolster machines worldwide with up to 20g vibration-resistance and absolute connection integrity in operating temperatures to +125°C. It can also condense PCB controls by up to 30%, making machinery more efficient to export.
picoMAX
Different by Design: picoMAX uses the contact force from one Cr-Ni CAGE CLAMPS contact spring to clamp a conductor and connect the header pin. Minimizing height, the female header is virtually encased within a male header for shock- and vibration-resistance without extra-cost measures, e.g., threaded interlocks. Furthering international appeal are clear terminations: Push-in for solid and ferruled conductors; push-button-actuated for stranded conductors.
Applications include: medical devices (analyzers, incubators), transportation (elevator/escalator controls), test/measurement (calibration and energy-monitoring devices), building control (BACnet devices, fire/security and lighting control systems) and IT (network gateways, routers).
Economical, Compact – picoMAX eCOM: Providing additional efficiency to cost-sensitive machinery, picoMAX eCOM Pinstrip Pluggable Terminal Blocks do not feature a pin housing. Pluggable female connectors can be directly soldered to PCB and wired as a terminal block. The female header can be removed for PCB maintenance without altering wiring.
WAGO
www.wago.us
Filed Under: Connectors (electrical) • crimp technologies, Terminal blocks, ELECTRONICS • ELECTRICAL
Tagged With: WAGO
