WAGO Corporation’s 753 Series Pluggable I/O Modules and High-Density 16-Point I/O Modules have earned GL Marine Approval. This enables WAGO to offer more than 150 marine and offshore products with multiple marine ratings including ABS, BV and DNV.
GL-Approved 753 Series Pluggable I/O Modules and Connectors: Based on standard 750 Series WAGO-I/O-SYSTEM modules, 753 Series provide convenient, pluggable field wiring via 753-110 Pluggable Connector. GL-Approved Pluggable Connectors are ideal for applications, such as marine systems, that require removal of a module in the fieldbus node without disturbing existing wiring.
The separation of function and wiring layers enables 753 Series to eliminate wiring errors while expediting changeover via pre-wired connectors. 753 Series provides conveniences such as coding options and strain relief, as well as direct testing for commissioning and maintenance.
GL-Approved 16-Point I/O Modules:WAGO 16-Point I/O modules feature 16 inputs, 16 outputs, or 8 inputs/8 outputs in a 12mm-wide module. Available with either CLAMP®S Spring Pressure Connections or HE10 flat Ribbon Cable connection, the 16-Point I/O Modules are among the most compact solutions for streamlining control-to-machine wiring.
Flat ribbon cable variants enable the use of pre-wired assemblies to minimize wiring time and errors, while providing multiple connection options. The CAGE CLAMP®S modules offer quick and reliable connections for 24 V DC I/O.
WAGO Corporation
www.wago.us
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical, I/O modules
