    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
WAGO’s D-Sub Interface Modules
By Design World Staff | October 30, 2008
GERMANTOWN, WI ‚– WAGO Corporation‚’s Custom Products Division has engineered a new line of 26-pin D-sub interface modules (product number 51013375) for motion control applications. The high-density, male interface modules have been paired with WAGO‚’s 737-109 Triple-Deck Terminal Strips to provide efficient control-level connections for electromechanical devices.
The 26-pin D-Sub interface modules offer straightforward integration with 1-to-1 pin contact for proper signal transmission and distribution. Use of the 737-109 Triple-Deck Terminal Strips enabled WAGO engineers to provide a PCB that is approximately 1/3 the width of traditional blocks. The triple stacked terminal configuration also makes determining pin-to-terminal correspondence simple.
The robust, DIN-rail mountable interface modules provide convenient wiring for conductors AWG 28-12. Utilizing CAGE CLAMP‚® Spring Pressure Connection Technology enables the D-Sub interface modules to provide fast, easy and maintenance-free wiring along with an operating temperature range of -25‚°C to 55‚°C. The D-sub interface module‚’s 737-109 front-entry terminal blocks also feature a test port for convenient troubleshooting.
The 51013375 26-pin D-sub Interface Modules are in stock and available. WAGO‚’s Product Development Division has the capability to custom engineer and manufacture components to exacting specifications. Please contact the factory for details.
www.wago.us
Filed Under: I/O modules, Motion control • motor controls, Terminal blocks
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
