WAGO’s LEVER-LUTION continues with new PCB Terminal Block
By Heather Hall | October 3, 2022
WAGO’s new 2601 Series is the first super-compact, tool-free PCB terminal block with lever technology, allowing quick and easy wiring for cross-sections from 26 to 14 AWG.  With the ability to be connected both vertically and horizontally to the PCB and with a pin spacing of just 3.5 mm, this terminal block takes up minimal space on the board.
Thanks to WAGO’s patented Push-In CAGE CLAMP connection technology, solid and fine-stranded conductors with ferrules can be connected simply by pushing them into the block. The levers ensure that the contact point is always secure, making the PCB terminal blocks suitable for device connections in the field, no matter the performance class.
WAGO
www.wago.com
Filed Under: Terminal blocks
Tagged With: WAGO, WAGO Corporation
