Water-Dropping Helicopter Technology Is Tested
By AP News | June 15, 2018
Southern California agencies are field-testing equipment intended to enable helicopters to more quickly fill with water while battling wildfires.
Anaheim Fire & Rescue, the Orange County Fire Authority and OC Parks demonstrated the Remotely Activated Snorkel Site technology on Monday.
Snorkels are hoses that allow hovering helicopters to suck loads of water out of natural and man-made sources.
A prototype of a tank that will serve as an “aerial fire hydrant” sits off Avenida de Santiago in Anaheim, Calif., Monday, June 11, 2018. Southern California agencies are field-testing equipment intended to enable helicopters to more quickly fill with water while battling wildfires. Jeff Gritchen/The Orange County Register via AP
The experimental system involves strategically placing portable open-top tanks or permanent basins in the environment and connecting them to municipal water sources.
A helicopter pilot uses a radio signal to activate valves and fill a basin near a fire, reducing the need for ground crews and cutting the time spent flying to load up with more water.
Filed Under: Test + measurement • test equipment
mti
MTI
moog
