Models SM23165MT-IP67 and SM34165MT-IP67 provide the same level of particulate protection, with the added advantage of being submersible up to one meter, and are protected against the effect of water or other non-hazardous liquids immersion for up to 30 minutes. The motor casing is completely dust tight and protected from liquid entry at any angle, rendering no harmful effects on the electrical enclosures. The sturdy design and thicker motor casing provides protection, durability, and resists cable stresses, meaning a longer motor life and less down time. These motors meet both IP65 and IP67 standards at the same time!
Applications for these IP67 SmartMotor products are endless.
New Application Opportunities:
What are IP Ratings?
IP ratings are in accordance with the code defined in international standard IEC 60529. Instead of the vague descriptions of “waterproof”, “water-resistant” or “dust-proof”, the IP rating system provides a uniform, quantifiable set of standards to which each product is rigorously tested. The IP code refers to the degree of protection for the electrical enclosures on a machine against liquid, solid objects and particulates. The first number following “IP” refers to the level of protection of the hazardous parts and electrical enclosures against solid objects and particulates, and the second digit indicates the level of water resistance. The higher the first digit rating in the IP system, the smaller the foreign object that it is protected against. The SM23165MT and SM34165MT is IP67 rated and thus has the highest possible protection from solid matter: it is completely dust-tight. With this rating, any wood, concrete, wheat or grain, plaster or other material processing applications usually resulting in fine byproducts are completely accessible with the SM23165MT and SM34165MT.
Moog
www.moog.com
Filed Under: MOTION CONTROL
