Waterproof Digital Thermometer from Omega
By Patrick Curran | August 8, 2011
Omega’s new DP8891 series of waterproof digital thermometer features a wide temperature range and can be used as a portable unit or a wall mounted large LCD meter. This battery powered unit is easy to use and is Celsius and Fahrenheit switchable. The meter and probe (when connected together) offer waterproof (IP67) rating. The DP8891 series comes complete with probe, probe holder, 4 “AAA” alkaline batteries and wall mount hardware. Perfect for monitoring temperature in a food processing application where a battery powered instrument is required in an area where there may be exposure to water splashes. Ideal for Water, Chemical and Automotive industries.
Omega Engineering
www.omega.com
Filed Under: Sensors (position + other), Sensors (temperature), Test + measurement • test equipment
mti
MTI
moog
