Watlow’s POWERSAFE medium voltage thermal system
By Mike Santora | January 18, 2022
Watlow, an industry leader in the design and manufacture of complete thermal systems, announced the launch of its new POWERSAFE medium voltage thermal system, which is a fully integrated heating and control solution that is a safe, reliable, and clean replacement for fossil fuel alternatives in process equipment.
The POWERSAFE system integrates an electric heat exchanger, process controller, and power system, as well as an isolated low voltage enclosure including an HMI and PLC. It also incorporates a flexible combination of a SCR and contactor circuits up to 20 megawatts delivering high-efficiency power greater than 99%, which reduces the overall size and weight of the power controller solution. The system operates safely and reliably up to 4160 volts eliminating the need for costly step-down transformers. It operates at low current allowing for up to a 90% reduction in cable costs.
The system offers other safety benefits as well such as a high-speed protective relay and breaker for rapid shut down to protect personnel and equipment and safety interlocks for protection during operation.
“Watlow’s new POWERSAFE system is an important piece in the electrification process,” said Dennis Long, chief system designer for Watlow’s energy and environmental technologies business unit. “Manufacturers are shifting from fossil fuel-based energy systems to electric
systems to help decarbonize. POWERSAFE is a clean, safe and reliable solution to help make the transition as painless as possible.”
Watlow
www.watlow.com
Filed Under: Controls (not motion controls), HMIs • operator interfaces • monitors
Tagged With: Watlow
Micro Controllers and Design Software optimize smart machine design
ReeR MOSAIC safety controller components
CLICK PLUS serial communication option slot module and 2-slot CPUs
z6257-57xT-green-cpd-std-srgb-web
Kubler 573T Touch process controller with 2 analog inputs
