Want to get into the wearable sensor craze? The PNI SENtrode development kit integrates sensors with its SENtral sensor hub, sensor fusion algorithms, programmable processor and wireless capabilities into a bracelet-sized form factor.
The kit includes a small form-factor board with an accelerometer, gyroscope, magnetometer and pressure sensor as well as an integrated heart rate monitor (HRM) mounted on an auxiliary sensor board. Humidity and gas sensors will also be available on additional auxiliary sensor boards.
SENtrode for wearables is 31.55mm x 37.15mm x 8.28mm with a bracelet. A second kit is available for IoT devices that is 31.55mm x 37.55mm x 8.65mm.
For more information, click here.
Filed Under: Sensor Tips
