Every application has unique requirements and functionality. Choosing the best pneumatic valve for the best performance requires knowing how to select based on specifications. The specifications are based on many factors from the type of valve design to the flow of the flow of the valve.
This webinar covers the basic valve designs and the best applications for their design. You will learn when an air piloted valve is used versus a solenoid piloted valve, the difference between direct acting solenoid valves from indirect acting solenoid valves and when they are best applied in a project and how quality of air, size and speed contribute to the valve selection.
What is Cv? How do response times and fill and exhaust help with valve specifications? Lastly, you will learn how to determine valve failure issues. Overall, this webinar provides technical and practical ways to properly specify a valve and how to troubleshoot in the event one should fail.
You will learn:
- Design types features & benefits
- Types of actuation
- Sizing/Flow rates (speed)
- Fail safe
Download Slides
Filed Under: WEBINARS, Pneumatic Tips
