    • Subscribe!
Wedge Base LED Lights Enable Design Versatility
By atesmeh | December 10, 2009
JKL Components’ LE-0903 Series of flat top wedge-base LED lights features a low 20 mm profile for use in switches. It is available in neutral white with either 12 V or 24 V AC/DC voltage, allowing for design versatility. The LE-0903 is said to improve existing applications using traditional lamps by providing durable long life LED technology in a T-3¼ wedge. The RoHS-compliant LED lights offer a 120-degree viewing angle with high brightness and light output which is comparable to 3 W wedge base lamps. The three cylindrical LEDs embedded in the wedge base provide even light distribution. Applications include display lighting, gaming machines, panel illumination, landscape & architectural lighting and others.
JKL Components Corp.
800-421-7244, www.jkllamps.com
    • Subscribe!
