Weidmuller AC DIN-Rail Receptacles
By Patrick Curran | July 8, 2009
RICHMOND, VA — Weidmuller announces the introduction of a new line of AC DIN-rail receptacles— the new DRAC Line. These DIN-rail receptacles are a further addition to Weidmuller’s existing line of simplex, duplex, and GFCI in-panel receptacles. The DRAC line provides users with a convenient power source inside the control cabinet for laptops, test equipment, lighting, solder irons and much more.
Weidmuller’s new DRAC Line of AC DIN-rail receptacles
Compact at only 2.9” wide and 4.6” high, Weidmuller’s new DRAC line of DIN-rail receptacles are fully enclosed and touch safe. They include 15A or 20A power outlets that provide a simple and convenient power source inside a panel or enclosure.
The DRAC line offers design flexibility and savings on installation time. The receptacles are ready to install right out of the box, and can be installed onto 35mm DIN-rail or, for added convenience, directly panel-mounted. The receptacles accept solid or stranded wiring from 20AWG to 10AWG.
The DRAC line is UL approved for use in any UL panel or control system. The UL508A and cULus approvals coupled with NEMA ratings make it effortless to add to a control cabinet or system.
Weidmuller
www.weidmuller.com
Filed Under: Electronics • electrical
molex-premo-flex
