Starting immediately, automation professionals can obtain terminal blocks from automation24.com. The online shop offers Universal Range Terminal Blocks from Weidmüller with Push In technology or with screw terminals. These modular terminal blocks have a streamlined design, high mounting density, copper power rails, and large marking surfaces to support efficient installation and maintenance.
“We hold ourselves to the standard of offering our customers as much as possible all in one place,” said Will Kleemeier, VP General Manager of Automation24. “After adding Siemens LOGO! logic modules to our product range this past year, we also decided to offer the accompanying terminal blocks to integrate it into your system with ease. Moving forward, we will continue to expand this product category in conjunction with the expansion of our complete product range.”
Weidmüller products reduce connection times for both solid and ferruled wires in addition to their professional grade tools – also available at Automation24.
The terminal blocks offered at automation24.com cover all connection requirements in an electrical enclosure such as PE, Fuse, Feed-through, Multi-tier, Test disconnect, and Neutral conductor disconnect terminal blocks. Newly added, Weidmüller’s Klippon Connect Universal Range terminal blocks include the A-series Push in spring connection type and the W-series clamping yoke screw connection type. Terminals are offered from 6.3 to 269 A and up to 250 MCM wire. In addition to being robust and reliable, they are designed to be clearly arranged and easy to use.
For a limited time, Automation24 is offering Weidmüller Thermal MultiMark Printers for only $1.00 with a qualifying purchase of marking consumables/accessories. The THM thermal transfer printer offers a compact solution for a variety of print jobs and provides a simple solution for manufacturer-independent terminal marking. This deal is available through June 30 at www.automation24.com/printer.
Automation24 Inc.
Filed Under: Terminal blocks
