Weidmuller’s New PRO-M Power Supplies
By Patrick Curran | February 9, 2010
RICHMOND, VA – Weidmuller announces the introduction of a new series of economical, general-purpose industrial power supplies– the PRO-M Series. The PRO-M Series power supplies have been optimized for use in practically all DC power applications, with a wide range of AC/DC inputs and an extended temperature range of -25° C to +70° C. These new power supplies feature a slim housing design and high power reserves for reliable start-up of loads with high inrush currents, such as motor starting applications. Excellent electrical specifications and high immunity against fluctuations in input voltage or “Brown-outs” make these compact modules the best choice to power sensitive loads in applications such as tooling and molding.
One of Weidmuller’s new PRO-M Series Power Supplies
Weidmuller’s new PRO-M power supplies are available in six single-phase and four three-phase models with 24 VDC output voltages, and up to 40A output currents. This voltage range enables the PRO-M Series supplies to be used in virtually any single-phase or three-phase application. “The PRO-M series allows for design flexibility, is a space saving solution and has platform assurance for any 24 volt control system,” said Tobin Robertson, Product Manager.
All of the new power supplies include innovative features such as integrated overvoltage temperature protection, available diagnostic output, external shutdown ability, a power OK signal, and convenient remote ON/OFF functions which make the units easy to maintain or troubleshoot.
Designed for use in numerous applications around the world, the PRO-M Series power supplies are UL and CSA approved. They feature a rugged metal housing, vibration- and shock-proof construction, and an operating temperature range of -25°C to +70°C.
The PRO-M Series offers users easy installation with detachable screw terminal blocks and snap-on DIN-rail mounting. For added flexibility, mounting tabs are also included for direct panel mount.
Weidmuller
www.weidmuller.com
Filed Under: Power supplies, Terminal blocks, ELECTRONICS • ELECTRICAL
