The Sensor Connection a division of Harold G. Schaevitz Industries, has expanded its sensor products by offering their Weld Pad Surface Temperature Thermocouple Probe. Designed for use in industrial applications to measure surface temperature by way of attachment via weld, braze, or clamp. The Weld Pad Surface Temperature Thermocouple Probe is flexible to easily form to the contour of a flat or curved surface. Made in the USA with high-quality materials, this probe is designed to withstand even the most rigorous operating conditions.
The Weld Pad Surface Temperature Thermocouple Probe is designed to deliver high-performance temperature measurements, reliably and consistently. These temperature sensors are designed for research and development, test labs, manufacturing engineering, and motorsports environments. They can be customized for OEM applications as well.
• Pad material is 304 stainless steel
• Pad dimensions are 1.0 in. x 1.0 in. x 0.01 in. (25 mm x 25 mm x 0.25 mm)
• Pad can be brazed, welded, or clamped to surface
• Stem is flexible
Filed Under: Sensor Tips
