    • On the Floor
What are low-profile screws?
By Mike Santora | June 10, 2024
Hiroki Goto, Engineering Manager — NBK America LLC
low-profile-screws-drone-in-flight-shot
Drones are designed to minimize air resistance and achieve efficient flight. Using low-profile screws in their assembly helps maintain a smooth, lightweight surface, reducing protrusions that could disrupt airflow around the drone.
Low-profile screws are designed with a lower head height than typical screws. These fasteners are designed with a minimal or flush head that sits close to the surface of the material being fastened for low visibility but secure fastening. Sometimes they’re also referred to as slim head, micro, or low-profile cap screws.
The smaller size with thinner (lower) heads means these fasteners are usually used for smaller devices and equipment or where clearance is limited. For example, they’re ideal for applications with limited space for bolt mounting. With minimal protrusion after mounting, they can also reduce concerns about interference.
These screws also solve certain problems like fastening to thin sheets where counterboring is impossible. In such cases, regular screws require deep counterbored holes, calling for larger surface material. Low-profile screws completely eliminate the need for counterboring.
Additionally, these screws are commonly used in applications where aesthetics matter and the appearance of the fastened surface is important. By design, low-profile screws offer a sleek, discreet appearance.
low-profile-scerws-1Typical features
  •  Head design: Low-profile screws typically have a flat or slightly countersunk head design. The head is either flush with the surface or slightly recessed, ensuring minimal protrusion.
  • Reduced height and weight: Compared to conventional screws, low-profile screws often have a shorter overall length, allowing them to remain nearly flush with a surface without protruding. The thin head means these screws are lighter than ordinary screws, making them ideal for certain lightweight applications.
  • low-profile-screws-2
    Low-profile screws are ideal for use to prevent interference when opening and closing equipment doors (top image) or for equipment that does not allow for deep countersunk holes.
    Thread size: Sometimes, low-profile screws also have a reduced thread height, where the threads are shorter to prevent them from protruding out the other side of the material. This is helpful in the context of fastening materials with limited thickness.
  • Variation: Much like typical screws, low-profile screws are available in various sizes, materials, and drive types, providing flexibility for different applications and a range of industries.
Applications
Given their minimal design, low-profile screws are widely used in the electronics industry for securing components, circuit boards, and electronic enclosures. Their flush or recessed heads minimize interference. They’re also used in drones, automation robots, and even certain automotive components (securing interior trims, panels, and consoles) because these fasteners are lightweight, enabling energy savings and smooth movement.
Thanks to their aesthetic nature, these fasteners are also frequently used in cabinetry, woodworking, and the furniture industry to secure hardware. They provide a clean and unobtrusive appearance while maintaining structural integrity.
Low-profile fasteners are also used in critical applications, such as medical devices and other applications where space and weight are critical factors.
Choose wisely
There are several advantages to using low-profile screws given their smooth, lightweight characteristics. However, it’s important to do your due diligence and choose the fastener that best fits the application.
Although these screws offer secure and reliable fastening in most applications, the thin head of these screws is not always an advantage. For instance, it can mean lower strength compared to conventional hex socket head cap screws. Low profiles may also have different widths across flat from hex socket head cap screws.
Also, when using both hex socket head cap screws and low-profile screws, different tools may be required, causing extra challenges.
Low-profile fasteners ensure minimal protrusion after mounting, reducing the risk of snagging, catching, or interference.
The advantages of low-profile fasteners…
  • Minimalism – a thinner head means these screws are smaller and lighter than typical screws, making them ideal for space-saving designs, smaller devices, and lighter-weight equipment
  • Safety – low-profile screws reduce the risk of catching, snagging, or even injuries that can result from exposed or protruding screw heads.
  • Aesthetics – a clean, smooth appearance
  • Maintenance – for the most part, smaller, low-profile fasteners mean easier maintenance
NBK
www.nbk1560.com
Filed Under: Assembly automation, Screws • nuts • bolts • rivets
Tagged With: nbk
    • On the Floor
