What are the (almost) nine IEEE single-pair Ethernet standards?
By Jeff Shepard | May 24, 2024
Eight existing IEEE single-pair Ethernet (SPE) standards exist, with a ninth expected to be announced next year. Current standards include 802.3bw (100BASE-T1), two types of 802.3bp (1000BASE-T1), 802.3ch (10BASE-T1) optimized for automated environments, three versions of 802.3cg (10BASE-T1S, 10BASE-T1L, and 10BASE-T1M), and the 802.3da single-pair multidrop segments enhancement standard that was approved in 2023.
This article reviews the eight existing SPE standards and closes with a preview of 802.3dg, which is expected to be published by the end of 2025. The next article in this five-article series will begin a deep dive into multidrop SPE by answering the question, “How does multidrop SPE work?” Other articles in the series will look at multidrop SPE architectures, PHY implementations, and technical requirements for interconnects.
SPE is designed to simplify Ethernet implementation. It builds on Fast Ethernet, which uses two cable pairs, and Gigabit Ethernet, which requires four cable pairs (Figure 1). Some SPE standards can transmit power in addition to data using Power over Dataline (PoDL) technology.
Figure 1. The three types of Ethernet cabling. (Image: CAE Group)
Eight ways to use a single pair
SPE technology has been embodied in many standards to support specific application needs. The first IEEE SPE standard was 802.3bw (100BASE-T1). It was released in 2015. Designed for use in automotive environments, it can support up to four series connections in a point-to-point (P2P) architecture with two mating connections with transmission rates of up to 100 Mbps over a total distance of up to 15 m. Subsequent SPE standards (in the order of release) include:
802.3bp (1000BASE-T1) includes two types and was released in 2016. Both support data rates up to 1 Gbps and P2P architectures. Type A is for automotive systems using unshielded cables over distances up to 15 m. Type B is for industrial applications using shielded cables and has a reach of up to 40 m.
The 802.3cg sub series, including 10BASE-T1S, 10BASE-T1M, and 10BASE-T1L, was released in 2019. 10BASE-T1S is for short-reach P2P and multidrop applications up to 15 m, while 10BASE-T1M is for multidrop applications with a reach of at least 25 m. Both support transmission speeds up to 10 Mbps and are designed for use in automotive applications like zonal architectures and industrial Internet of Things (IIoT) applications.
10BASE-T1S specifies that at least eight nodes be supported, while 10BASE-T1M requires support for at least 16 nodes. In addition, while the T1S standard supports PoDL, T1M supports an enhanced version of PoDL.
10BASE-T1L is for long runs up to 1 km in P2P networks, handles data rates up to 10 Mbps, and is compatible with PoDL. It’s designed to support industrial and building automation protocols like PROFINET, Modbus, BACnet, KNX, and LON. It specifies the use of a balanced pair of conductors and requires a shielded cable in electrically noisy environments.
802.3ch Multi-Gigabit Ethernet (10G/5G/2.5GBASE-T1) optimized for automative environments includes data rates of 2.5 Gbps, 5 Gbps, and 10 Gbps on a single balanced pair and a reach of 15 m. It was added in 2020. 802.3ch is designed for two purposes: to act as the in-vehicle network backbone to link various slower zonal functions and support Advanced Driver Assistance Systems (ADAS) like high-resolution, high-frame-rate, uncompressed video transmission for autonomous driving.
802.3da, released in 2023, provides enhancements to 10BASE-T1M multidrop technology. It doubles the reach to 50 m and supports regular PoDL powering instead of requiring enhanced PoDL. 802.3da adds a definition of the noise environment characterized by impulse and RF noise as defined in IEC61000-4-4, IEC61000-4-6, and CISPR25. It is intended to support operations in industrial, building, and transportation applications. It also adds the option for using dynamic physical layer collision avoidance (D-PLCA) node identification allocation.
Table 1. Summary of current SPE standards, except 802.3ch (10BASE-T1) optimized for automative environments with a data rate of 10 Gbps and a reach of 15 m. (Table: CAPIEL)
What will number nine be?
The ninth SPE standard will be 802.3de — Time Synchronization for Point-to-Point SPE. It will add time-sensitive networking (TSN) capabilities to 10BASE-T1L P2P networking. It will support data rates up to 10 Mbps over at least 500 m and is expected to be published in mid-2025.
Summary
SPE is not a single technology. It’s a diverse series of standards optimized for various applications like transportation (including automotive ADAS), industrial, and building automation. Various standards can support data rates from 10 Mbps to 1 Gbps and transmission distances up to 1 km. The next step in the development of SPE standards is expected to be the addition of TSN capability.
References
A technical paper of the Single Pair Ethernet System Alliance
Networking opportunities with Single Pair Ethernet for CAPIEL manufacturers, CAPIEL
New IEEE 802.3 Standards Provide Platforms for the Next Ethernet Innovations, IEEE Standards Association
Single Pair Ethernet: Applications and use cases studies: SPE Industrial Partner Network
Single Pair Ethernet: Standardization landscape: SPE Industrial Partner Network
Single Pair Ethernet is Driving IP to the Edge, Real Time Automation
SPE technology, the future of Industry 4.0 applications?, CAE Group
What is Single Pair Ethernet?, BotBlox
Filed Under: Connector Tips
Tagged With: FAQ
