As we have learned, lubrication failures are a leading cause of bearing damage. Oil levelers are designed for automatic adjustment of the optimal lubricating oil level within a bearing housing, gear box, crank case or similar oil bath lubrication application. Some oil levelers even allow for effective adjustments during running conditions, optimizing machine performance and increasing service life. Furthermore, they automatically compensate for lubricating oil leakage and offer the possibility of visual inspection of the oil level.
SKF
skf.com
Filed Under: Uncategorized
Sergio Rios says
Interesting, but what about the polymers? These need be a lubricated alsó or not?
I’m living in Denmark and I make predictive maintenance. Thanks for the information.
