What types of connectors are used in medical devices?
By Aharon Etengoff | April 2, 2025
Medical devices of all sizes and types rely on connectors to ensure safe and reliable power delivery, data transmission, and fluid management. Many of these medical-grade connectors are rated for biocompatibility (ISO 10993), environmental sealing (IEC 60529), and electromagnetic interference (EMI) resistance (IEC 60601-1-2).
This article highlights various medical connectors, such as implantable devices, card-edge solutions, and board-level interconnects. It also explores header pins, in-line options for board-to-board and wire-to-board integration, and spring-loaded connectors for wearable and portable medical devices. Lastly, the article reviews widely used medical-grade connectors, including circular metal and quick-disconnect tubing.
Specialized connectors for implantable medical devices
As shown in Figure 1, implantable medical devices such as pacemakers, cochlear implants, and insulin pumps incorporate specialized connectors engineered for long-term reliability, material compatibility, and high-performance operation.
connectors
Figure 1. Hermetic connectors featuring gold plating, Kovar alloy construction, and glass-sintered sealing technology for high-reliability performance in medical implantable devices. (Image: Sunkye)
These connectors prevent contamination and enable essential functions, spanning power delivery, data transmission, and wireless communication. They also minimize EMI and resist external disruptions to maintain signal integrity. Key features include:
  • Hermetic seals: provide airtight protection against pressure changes, moisture, and other environmental factors that could compromise electrical connections.
  • Biocompatible: enable safe implantation and consistent operation of pacemakers and defibrillators. Most implantable cardiac devices comply with stringent standards of IS-1, DF-1, IS-4, and DF-4.
  • High-density micro: this technology supports miniaturized implantable devices by integrating power, data, and sensor transmission in compact designs without compromising performance.
  • RF coaxial: ensure efficient wireless communication by maintaining strong signal transmission with minimal interference.
Many of these connectors incorporate durable, medical-grade materials such as plastics, metals, ceramics, glass, and high-performance polymers like PEEK and PEK. Certain designs feature insulation resistance of ≥5000 MΩ, air leakage rates of 1×10⁻³ Pa·cm³/s, and an operating temperature range of -40°C to 105°C. Notably, emerging microgasket technology achieves ~5 MΩ electrical isolation at 10 kHz, far exceeding conventional implant connectors.
Facilitating high-speed medical data transfers with card edge connectors
As shown in Figure 2, card edge connectors facilitate high-speed data transfer and complex processing by enabling printed circuit boards (PCBs) with edge-mounted contact pads to connect directly to other systems.
connectors
Figure 2. Card edge connectors with bellow-style contacts for vibration resistance, copper alloy contacts for low resistance, and gold plating for wear resistance. (Image: ConnectorSupplier)
Data acquisition (DAQ) cards convert sensor data in blood analyzers through analog-to-digital (A/D) sampling systems. Similarly, advanced patient-monitoring systems use card-edge connectors to expand storage or testing capabilities.
Medical-grade card edge connectors must meet strict reliability standards. Frequent mating cycles in high-vibration environments accelerate fretting corrosion and degrade contact surfaces, while reagent exposure further increases wear. Thicker gold plating prevents base metal oxidation, improves conductivity, and forms a protective barrier that minimizes material loss.
Implementing reliable board-to-board and wire-to-board connections
Manufactured with high-conductivity copper alloy, header pin connectors are widely used in medical equipment, such as X-rays, CT scanners, ultrasound systems, and MRI machines. They also support diagnostic cardiology devices, heart-lung support systems, patient monitors, and blood analyzers.
Header pin connectors provide reliable board-to-board and wire-to-board connections by minimizing resistance and maintaining robust contact force. High-power headers support up to 20A for board-to-board power applications, with integrated ground plane contacts improving electrical performance. For example, a 4 mm pin pitch minimizes arcing risk, ensuring safety in high-power medical systems.
While header pin connectors support both board-to-board and wire-to-board connections, in-line connectors provide a more compact solution for wire-to-wire and wire-to-board applications, particularly in medical wire harnesses. As shown in Figure 3, many medical header pin connector designs incorporate full-seal epoxy protection, achieving IP67 ratings for dust-tight performance and resistance to temporary fluid immersion in medical environments.
connectors
Figure 3. EDAC’s in-line connector with E-Seal technology features a proprietary epoxy process that seals the entire back of the connector rather than individual pins. This design achieves an IP67 rating, providing dust-tight protection and resistance to temporary water immersion. (Image: EDAC)
Spring-loaded connectors for wearable and portable medical devices
Spring-loaded (pogo-pin) connectors facilitate reliable charging and docking for wearable health monitors, portable medical devices, and home health equipment. Many designs incorporate magnetic alignment to improve stability and ease of use. Ruggedized, IP-rated versions resist vibration and minor misalignments, ensuring continuous operation in compact applications such as hearing aids. Spring-loaded connectors maintain stable contact during turning, walking, and running.
Medical-grade connectors for data, power, and fluid management
Beyond implantable and board-level connectors, various medical-grade connectors facilitate secure data transfer, reliable electrical connections, and efficient fluid management in critical medical applications. These include:
Quick-disconnect tubing: Figure 4 shows that these connectors enable secure, leak-free fluid and air transfer. Valved mechanisms seal upon disconnection, preventing leaks and contamination, while biocompatible materials and chemically resistant seals withstand exposure to disinfectants, medications, and sterilization processes.
Circular metal: circular metal provides durable, high-reliability connections. Metal housings offer superior EMI shielding, and IP68-rated sealing guarantees sterilization resistance. Multiple keying options prevent misalignment, and high mating cycle durability supports long-term use in harsh and demanding environments.
USB: USB facilitates data transfer and connectivity in patient monitoring systems, diagnostic equipment, and medical imaging devices. Medical-grade USB connectors feature ruggedized designs, waterproof sealing, and secure latching mechanisms for extra durability.
HDMI: HDMI supports video displays in medical imaging applications, such as point-of-care ultrasound. These systems require multiple video output options, including VGA, DVI, HDMI, and legacy formats like S-video or C-video. Designed for demanding environments, medical-grade HDMI connectors resist vibration, mechanical shock, and moisture exposure. Their waterproof designs incorporate protective sealing to prevent splashes and shield against corrosive substances.
D-subminiature (D-sub): this connector enables sensor and actuator connections in medical monitors while ensuring robust electrical performance. Gold plating and secure mounting prevent contact degradation from constant vibration, and specialized IP-rated sealing protects D-subs against dust and moisture. Many connectors incorporate metal shells grounded to the chassis and cable shielding to minimize EMI and maintain signal integrity.
RF: this connector type transmits high-frequency signals in applications such as MRI machines, ultrasound equipment, and patient monitoring systems. It requires precise impedance matching and robust shielding to maintain signal integrity and prevent EMI. Medical-grade RF connector designs are also integrated into wearable devices to facilitate reliable wireless communication.
Conclusion
In implantable, wearable, and diagnostic devices, medical-grade connectors support reliable power delivery, data transmission, and fluid management. Advanced materials, precision engineering, and environmental sealing allow these connectors to withstand high vibration, frequent mating cycles, and harsh clinical and physiological conditions.
References
Electrical Connectors: Design Considerations for Medical Devices, Medical Design Briefs
Medical Connectors 101, AmphenolAlden
What Are the Different Types of Medical Connector Product Solutions?, AmphenolAlden
Implantable Medical Devices Depend on High Quality Connectors, ConnectorSupplier
Six Common Connector Types Used in Medical Devices, ConnectorSupplier
Medical Devices and Electrical Connectors Technology, ProMax
Hermetic Connectors for Implantable Medical Devices, SunkEye
How to Choose a Medical Connector, ConnectorSupplier
Six Common Connector Types in the Medical Field, Konnra
Related EE World Online content
Why is Signal Integrity Crucial for High-Speed Connector Designs?
Why and How are Medical Connectors and Standards Different?
What Are the Six Connector Locking Mechanisms?
What Plating Options are Available for High-Power Connectors?
What Are the Most Common Connector Styles Used for MV Systems?
Filed Under: Medical-device manufacture, Connector Tips
