Whisper Vane Transfer Pump from VARNA
By Paul Heney | April 29, 2011
VARNA Products introduces their new “Xtreme Duty” Whisper Vane Transfer Pump Model “XD4”.
VARNA’s latest design draws on their lineage of pump designs and it is the sister to their Model EP4 Prelube Pump. Made of TYPIII hard anodized aluminum, carburized carbon steel, the “XD4” has shown to perform well in a wide variety of transfer applications where extreme temperatures exist for both high & low temperature. The “XD4” is currently employed in the field in 2 countries with different OEMs.
The “XD4” pump delivers up to 4 gpm (15 l/m) of oil flow, is self-priming, quiet running, utilizes VARNA’s whisper-vane technology and is for use with non-corrosive fluids such as oils and coolants. It can produce up to 60 psi (4bar) pressure at nominal voltages of 12 thru 24vdc. The “XD4” has a permanent magnet motor capable of doing an extraordinary amount of work for its size and can be used in certain continuous-duty applications.
VARNA-xd-4-oil-pump-d
The “XD4” complements VARNA’s line of pumps and turnkey controls used in prelube and transfer applications in experimental flight, fuel cell, off highway, oil/gas, over the road transport, rail, power generation, and more.
VARNA Products
www.VARNAProducts.com
Filed Under: Hydraulic equipment + components, Pumps, Off highway • construction • agriculture
Paul Heney
