Why torque is a critical part of security fasteners
By Michelle Froese | December 17, 2019
Click here to watch Bryce Security Fastener’s latest video on torque.
Torque is the essential part of the security of a security fastener. This means that the more weight a screw holds, the more secure it should be and the more pressure will be required to remove it.
However, if there is not enough tension when installing security screws, there can be a problem.
Although rare, fasteners can sometimes have an issue with getting breached. According to Bryce Security Fastener, the biggest reasons why a breach occurs relates to torque. Why? Well, either the fastener was not torqued tight enough or it was installed into the wrong substructure.
As mentioned above, if tension is inadequate when installing security screws, they may fail. Bryce tested their own fasteners with common store-bought security screws to show users the difference between torque values and why they’re so important. Watch the video here.
brycefastener.com
Tagged With: brycesecurityfastener
  • Tech Toolbox: Designing for cleanrooms
