Chargers and transmitters power up drones, autonomous mobile robots
By Lee Teschler | August 17, 2021
New cutting-edge chargers and transmitters for drones and autonomous mobile robot include:
•OC-262 onboard charger. The OC-262 is a passively cooled onboard charger that was developed as a ruggedized wiboticsystem for the Department of Defense, but is now being released for wider use in response to customer demand. Passive cooling is particularly beneficial in punishing environments where water, dust, dirt and corrosion are significant concerns, and the OC-262 offers considerable benefits to customers operating in the oil and gas, mining, construction, marine exploration and agriculture industries. Providing up to 300 W of power, the OC-262 has no moving parts, supports all common robot battery chemistries, and pairs with a weatherproof receiver antenna for a complete outdoor solution.
Two models of the OC-262 are now available, an ST model with IP20 rating for applications that require passive cooling but can be more open to the environment, and a WP model with IP67 rating for use in outdoor or extreme environments.
• OC-150 onboard charger. Designed for UAVs and smaller robots, the OC-150 is a compact and lightweight onboard charger that delivers up to 150 W of total power and up to 10A of current depending upon battery voltage. As with other OCs, it supports multiple battery chemistries and has an output voltage range of 9 to 58.5 V.
• TR-150 transmitter. A compact transmitter, the TR-150 uses the latest high-efficiency GaN transistors from WiBotic partner GaN Systems Inc. It is designed primarily for use with the new OC-150 onboard charger but supports all WiBotic OCs when deployed in diverse robot fleets. Delivering up to 150 W of power, its new GaN-driven power amplifier has an exemplary 95% efficiency – leading to end-to-end wireless power system efficiencies of 85% or more.
• TR-300 transmitter. Like the TR-150, the TR-300 is a compact wireless power transmitter using GaN Systems’ technology for maximum efficiency. The TR-300 offers the same core benefits as the TR-150 but delivers up to 300W of power when paired with WiBotic’s OC-262 or OC-301 onboard chargers.
Paul Wiener, VP of Strategic Marketing at GaN Systems, congratulated WiBotic on the announcement: “These new products are just as exciting for GaN Systems as they are for WiBotic. We continue to believe the market for high-power wireless charging systems is going to explode in the coming years and companies like WiBotic are going to lead the way through the use of GaN technology.”
WiBotic Inc., 9706 4th Ave NE, Suite 208, Seattle, WA 98115, (206) 580-0900, www.wibotic.com/
Filed Under: Power supplies, MOTION CONTROL
Tagged With: wibotic
