WIDIA has added an AL Geometry to its ISO Turning portfolio, strengthening its broad offering of affordable tooling solutions for small to medium-sized shops, machining aluminum and non-ferrous materials. The company is dedicated to delivering high-quality hole-making, tapping, milling, and systems tooling to metal-cutting customers, globally.
AL Geometry ISO turning insert is cost-effective, universal solution for medium to finish turning applications on aluminum and other non-ferrous materials.
The new AL Geometry insert is offered in two grades for increased machining versatility: an uncoated microfine carbide WU10HT grade and the PVD AlTiN coated grade, WU05PT. Each grade is available in all popular styles, including C, D, R, T, and V inserts to increase customer tooling options.
In addition to enhanced product versatility from multiple grades and style offerings, the AL Geometry insert offers a highly polished rake face that improves chip flow. This results in shorter setup times due to less manual retrieval of chips following each cut. The periphery ground insert also features a sharper cutting edge to increase overall tooling precision and reduce cutting forces.
Reliable tooling performances means customers can dedicate more time to machining and less time to post-machining deburring operations because of the reduction in built-up edge.
“The AL Geometry portfolio offers tooling versatility when machining different components and workpieces, while also providing more precise and reliable machining performance,” said Anil Kumar, WIDIA Global Turning portfolio manager. “By focusing on both tooling performance and value, we’re helping our customers maximize their return on our products.”
Versatile, reliable, and cost-effective, the AL Geometry is the universal solution for customers seeking lower cutting forces, extended tool life, and greater tooling productivity when machining a variety of non-ferrous workpiece materials, particularly aluminum.
Filed Under: MANUFACTURING
