Winco introduces line of knurled nuts & knobs.
By Design World Staff | August 31, 2007
J.W. Winco, Inc. now offers size inch as well as metric size Hollow Knurled Nuts.  The new knurled nuts are made of black nylon plastic with a smooth, glossy finish, and have tapped through inserts of zinc plated steel, molded in.  On clamping applications, the partially protruding insert prevents chipping of the plastic.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
