    • Subscribe!
Winters pressure accessories from AutomationDirect
By Mike Santora | July 28, 2022
automation-direct-product-shotAutomationDirect has added new pressure sensing accessories from Winters. These accessories will protect delicate pressure measurement equipment from damage caused by pressure surges, superheated media, and more.
Included in the new product release are siphons that protect pressure gauges, transmitters, and switches from the effects of high-temperature media such as steam. New pressure snubbers protect instruments by suppressing pressure pulsations and spikes.
Added manual isolation and throttling needle valves isolate instruments from the sensed media, while block and bleed valves isolate instruments with the added ability to bleed off unwanted pressure. Both valves also allow for quick and easy removal and maintenance of measurement instruments without shutting down the process.
Automation Direct
www.automationdirect.com/pressure-sensors
Filed Under: Uncategorized
Tagged With: automationdirect
MAR01764
Metrios Re-Light optical measuring machine accommodates both flat and cylindrical parts
te-raychem-heat-shrink-wrap--tubing-electrical-wires
Raychem teat shrink tubing / sleeves for electrical wires
Moticont - LVCM-019-048-02 Voice Coil Motor 4x5x300
0.750-in. diameter voice coil motor
robotics-smart-farming-faulhaber-products
Faulhaber: The smart future of agriculture
    • Subscribe!
