The new Crimpfox DUO 10 wire crimping pliers from Phoenix Contact are ideal when flexibility is required. The Crimpfox’s unique, rotating die permits frontal or lateral insertion of ferrules.
Engaging the color-contrasted release button enables the user to easily rotate the die to the necessary insertion direction, and the Crimpfox’s locking mechanism keeps the die securely in position. The pliers’ self-adjusting mechanism allows them to not only accommodate single ferrules but also reliably accommodate twin ferrules.
These crimping pliers cover a large cross-section range from 26-8 AWG single wires or 2×20 to 2×12 AWG twin ferrules. Its perfectly balanced, ergonomic design creates an ideal fit for the user’s hand. Its carefully engineered design makes it the lightest and most compact tool on the market. No intense force is required to operate the tool, allowing the user to work longer without fatigue all while producing high-quality results.
Phoenix Contact
www.phoenixcontact.com/handtools
Filed Under: Connectors (electrical) • crimp technologies
