With embedded magnets, compact gearmotors offer wide speed range
By Leslie Langnau | July 23, 2018
The IPMax is a line of efficient, lightweight, compact interior permanent magnet (IPM) gearmotors with a wide synchronous speed range. These gearmotors incorporate magnets embedded within the rotor, as opposed to on the surface. No copper losses are experienced in the rotor, and considerably less copper losses occur in stator winding. The gearmotors can operate fanless up to 1 hp, and do not require encoders for sensor control. When stopped, a servo lock feature holds the motor in position.
These gearmotors are 23% smaller than comparable ie3 motors, and run 24% cooler for longer lifespan. They employ brake sequential – which sets motor operations when the mechanical brake is turned on or off – as well as a torque limit solution that protects the mechanical system. Various functions of their programmable I/O terminals may be changed according to external circuits or applications. RS485 is included as standard.
Interior permanent magnet motors are suitable for conveyors, fans, and pumps, and are frequently used for factory automation, material handling, packaging, and food processing.
In addition to reduced size and weight, the IPMax gearmotors offer an ingress protection rating of 65 (IP65), meaning they are protected from total dust ingress as well as from low pressure water jets from any direction. Additionally, compared with a brushless dc gearmotor, the IPMax gearmotors feature simple wiring and are easier to connect. They also offer similar high efficiency without requiring any extra signal cable.
Brother Gearmotors
www.BrotherGearmotors.com
Filed Under: Manufacturing, Packaging, Motors (gearmotors)
Tagged With: brothergearmotors
beckhoff-control-cabinet-image
Right sized packaging to boost sustainability
Zip seal bags
Creating a greener package design
See a fully functional integrated packaging line at Pack Expo 2021
Packaging expos to reunite the packaging and processing industry this September in Las Vegas
