J.W. Winco, Inc. now offers series GN 6322 Workholding Pins in metric sizes.
These RoHS-compliant pins are inserted into bores for positioning, with the ball-type shoulder facilitating the insertion into the bore. The pins are tempered, hardened steel. Diameters range from 10 to 25 mm.
Type B is cylindrical in shape, while Type C has flattened sides on the pin. The flattened design of Type C provides tolerance for the spacing of the two bores. Another application of this design is to fix parts to be positioned in one direction only.
J.W. Winco
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
