WRAS approves Vesconite’s Hitemp 150
By Mike Santora | January 18, 2022
P1040322 Jean cropA wear-resistant bearing material produced by Vesconite Bearings, Hitemp 150, has been certified for drinking water use by the Water Regulations Approval Scheme (WRAS).
WRAS is an independent UK certification body for plumbing products and materials. It informed Vesconite that Hitemp 150 “is suitable for contact with wholesome water for domestic purposes”.
Hitemp 150 components met the requirements of BS6920-1:2000 and/or 2014. These standards govern whether non-metallic products are suitable for contact with water intended for human consumption.
UK manufacturers can hence confidently use the product, says Vesconite Bearings CEO Dr. Jean-Patrick Leger.
The certification also provides comfort for the general safety of the bearing material where it is used outside of the UK, he notes.
Vesconite Bearings
www.vesconite.com
Filed Under: Bearing Tips
Tagged With: vesconitebearings
SKF filtration system boosts oil lifetime
New high-performance ball bearing from Schaeffler
Vesconite planter bushings
SKF and Amazon Web Services collaborate
