Wye Cylinder Engineering recommends the use of iglidur polymer bearings from igus together with its products.
Offering improved reliability and maintenance-free operation, the bearings are typically used in a pivot point, which provides the end of a hydraulic cylinder shaft with an articulated coupling. Wye Cylinder Engineering has provided most of its customers with cylinders fitted with iglidur bearings.
Igus iglidur products are resistant to the effects of dirt and vibration, which is particularly important because the cylinders are used in demanding working conditions such as: a range of agricultural machinery, mini excavators, commercial and material handling applications to mention just a few where high levels of contamination are unavoidable.
igus
www.igus.com
www.wye-cylinder.co.uk
Filed Under: Bearings, Hydraulic equipment + components, Linear Motion Tips
