    • Subscribe!
Yokogawa Releases SENCOM Platform Products
By Test and Measurement Editor | October 29, 2013
Yokogawa Corporation of America announces the October 25 release of the new SENCOM platform product series for the digital measurement of pH and ORP. This will join an existing lineup of quality pH/ORP solutions that includes the FLXA21 two-wire* pH/ORP-transmitter. With the release of the SENCOM platform products, Yokogawa will bring pH and ORP measurement into the digital era.
The SENCOM platform initially consists of a SENCOM module, the FU20F pH/ORP SENCOM sensor, a SENCOM cable, and the SPS24 SENCOM PC software. The installation of a SENCOM module in an FLXA21 transmitter will give it the powerful digital signal processing capabilities required to work together with the new SENCOM sensors.
Like its predecessor, the FU20F pH/ORP SENCOM sensor is a general purpose sensor that is suitable for a wide range of applications. The FU20F can store digital data and be calibrated using the SPS24 SENCOM PC software and/or the FLXA21. With these SENCOM platform products, our customers will be able to reduce the amount of maintenance work that needs to
be performed on-site, thereby improving efficiency and reducing costs.
Development Background
Liquid analyzers are used in the oil, petrochemical, iron and steel, electric power, and water supply and wastewater treatment industries to control the quality of raw materials and products, monitor reactions, and manage the wastewater treatment process. The properties of certain solutions may cause damage to or foul the sensors in these analyzers and thus adversely affect measurement accuracy, so sensor calibration is required on a regular basis. However, conditions vary and it is not always safe or convenient to perform the calibration work on-site, which usually requires a converter to store data and the use of standard calibration solutions. There is a need to move this work to a safer location and also reduce measurement downtime.
Product Features
1. Better working conditions / reduced measurement downtime
The FU20F pH/ORP SENCOM sensor is able to process digital signals and store digital information, including calibration data. Using either the SPS24 PC software or an FLXA21 transmitter, it can do offline calibration of these sensors in a laboratory, where working conditions are optimal. In addition, the ability to swap out the FU20F and replace it with a
calibrated sensor on site will significantly reduce measurement downtime.
2. Quick and efficient calibration
With the SPS24 software, it will be possible to simultaneously calibrate up to four SENCOM sensors, significantly shortening calibration time.
3. Efficient data management
The SPS24 software features an integrated database capable of storing data for up to 100 SENCOM sensors. This enables predictive maintenance, allowing service staff to identify when sensor maintenance and/or replacement is required. In addition, there is no longer the need to go on-site to obtain the data stored on a converter.
Major Target Markets
Process industries such as oil, petrochemicals, iron and steel, electric power, and water supply and wastewater treatment
Applications
– Monitoring the quality of treated wastewater and neutralized water
– Controlling the concentrations of liquid infusion systems
* A two-wire system feeds power and transmits signals through a pair of cables, reducing wiring costs.
Yokogawa
www.yokogawa.com/us
The post Yokogawa Releases SENCOM Platform Products appeared first on Test & Measurement Tips.
Tagged With: Yokogawa
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
    • Subscribe!
