ZaGO introduces its new line of
silicone rubber switch seals. ZaGO is putting the full force of its
sealing expertise behind this product, applying the same high quality,
high utility engineering with which it supports its self-sealing
fasteners to its line of switch boots.
ZaGO supplies switch boots for toggle switches, push button switches
and rotary switches. ZaGO‚’s boots provide critical protection for
switches that are used in harsh environments and which are subject to
exposure to dust, dirt, moisture, precipitation and other contaminants.
Our boots protect both switches, and their mounting holes in corrosive
environments.
One of the main reasons switches fail are because they are not sealed properly leaving them vulnerable to corrosive environments. They are subject to exposure to dust, dirt, moisture, precipitation and other contaminants. With ZaGO’s Rubber Boots you can guarantee your switches and their mounting holes will be protected ensuring that the equipment will not fail.
All ZaGO rubber boots are crafted with a single-piece design and can be made DFARS and ROHS compliant.
Filed Under: Fastening + joining • locks • latches • pins, Safety systems + components, Screws • nuts • bolts, Switches
