Miki Pulley’s CSZ Electromagnetic Clutches have a zero backlash design. They provide an efficient connection between a motor and a load with low inertia, minimal drag and zero backlash.
Miki Pulley CSZ Clutches function utilizing the magnetic force generated by the energized coil providing engagement of input and output members of the clutch. They feature an integrated bearing design making mounting fast and easy while ensuring application concentricity and excellent system runout. CSZ Clutches operate well in temperatures from +14 to +104° F (-10to +40°C).
Available in bores ranging from 10mm to 15mm, with brake torques ranging from 1.77 ft. lbs. to 7.376 ft. lbs. (2.4 Nm – 10 Nm). The CSZ uses corrosion resistant materials, and is RoHS compliant like all other Miki products.
“Miki Pulley’s CSZ Clutches are a great choice for high performance printing, paper processing, packaging, food processing and textile manufacturing systems,” reports Jon Davidson, Miki Pulley sales specialist. “They are proven performers in system applications around the world.”
Miki Pulley
www.mikipulley.co
Filed Under: Coupling Tips
