Plymouth, MN – Zero-Max Adjustable Speed Drives with the new Micro Dial™ feature provide accurate and repeatable speed settings. This allows users to more accurately set and re-set various speeds to meet performance levels for different applications.
When the Adjustable Speed Drive with the Micro Dial is used in a seeder cart application, for example, different settings can be made more accurately for dispensing corn, wheat, oats, etc. Similarly, in textile applications, the Adjustable Speed Drive can be set with the Micro Dial for precise speed control in textile winding machines.
Accepting input speeds from 0 to 2000 rpm, output speed changes using these Adjustable Speed Drives can be made quickly and easily, whether the machine is running or not. For example, output speed is infinitely adjustable from 0 to 400 rpm with an 1800 rpm input speed. The drives provide speed control for inputs from ¼ to 1-1/2 HP applications with output torque ratings from 12 through 200 in-lbs.
Zero-Max Adjustable Speed Drives can be used as a prime mover connected to a motor, or as a secondary drive connected to a shaft in the machine’s drive line. When used as a prime mover, the drive acts as a variable speed device. When used as a secondary drive, it becomes a variable ratio device. The drive permits slow or fast, small or large speed changes.
Output speed for the drive is set quickly with the hand wheel adjustment. The Micro Dial provides a clean and accurate reference for applications that require repeatability.
Zero-Max
www.zero-max.com
Filed Under: Drives (ac) + VFDs + starters, Drives (dc), Motion control • motor controls
