Zero-Max Launches New Configurable 3D CAD Downloads
By Design World Staff | January 18, 2008
Minneapolis, Minnesota – Now you can select and configure the
exact CD® coupling solution for your coupling application with 3D
Partstream.
Zero-Max's latest generation CD couplings are easier and faster to evaluate and specify than ever before.
To select the right CD coupling, for example, the system
designer simply enters the coupling size or max torque capacity and the
two bore sizes.  3D Partstream then will render the exact configured
coupling for Interactive viewing.  That exact configuration can be
downloaded in a multitude of CAD formats to be quickly and easily
imported to the drawing.  At this point, a quote request is as simple
as a click of the mouse.  No more modifying a generic one size fits all
drawing.  Zero Max will give you the exact drawing of what you need
right down to the bore size.
The new CD couplings feature zero backlash precision and
high torsional stiffness required in today's demanding servo motor
applications with high reverse loads and positioning requirements.
Manufactured of RoHS* compliant materials containing no
banned substances, these newly improved CD couplings are designed with
new clamp style hubs for increased torque capacity on shafts without
using keyways.
Zero-Max
www.zero-max.com
:Design World:
Filed Under: Couplings
