Zero-Max Torq-Tenders offer a pre-set torque value for consistent machine operation
By Mike Santora | March 25, 2019
Zero-Max-torq-tender-imageThe Zero-Max Torq-Tender is an enclosed device with no external adjustment features. It has a pre-set torque value and once installed, cannot be changed. This feature safeguards against improper or unauthorized torque adjustments.
Designed to avoid system damage, Zero-Max Torq-Tenders provide dependable overload protection. When a jam-up or excessive loading occurs, the built-in Torq-Tender will reliably and quickly release to prevent system damage. Proper torque setting ensures that the machine operates and reacts the way it was intended to operate. The Torq-Tender’s pre-set torque with no external adjustment feature, ensures the proper torque setting is maintained.
Additional Zero-Max Torq-Tender features include:
Standard Torq-Tenders are bi-directional. Torque values remain the same regardless of rotation. If specified, the Torq-Tender can be configured at the factory to release at different torque ratings for different rotational directions.
When used as a coupling, the Torq-Tender fulfills two functions: (1) as a flexible shaft coupling and (2) as a mechanical torque limiter.
Designed with heat treated steel, Zero-Max Torq-Tenders are manufactured and assembled to operate in a wide variety of demanding industrial environments. Special designs and finishes are available to withstand the most adverse operating conditions.
Zero-Max
www.zero-max.com
Filed Under: Coupling Tips
Tagged With: Zero-Max, Zero-Max-Inc
Friction bearing universal joints for packaging applications
Sensata Technologies adds Predictive maintenance for rotary equipment
KTR RUFLEX torque limiter with BoWex gear coupling
Ringfeder on Carlyle Johnson JEB electric jaw clutches
