Zero-Max VRT Variable Ratio Transmission For agricultural seeding and fertilizing applications
By Mike Santora | March 22, 2021
8603 ZERO-MAX VRT ImageZero-Max new VRT Variable Ratio Transmissions feature an efficient and cost-effective design that ensures accurate and consistent application rates for agricultural seeding and fertilizing equipment.
The Zero-Max VRT is designed to meet the performance requirements for today’s agricultural equipment. The VRT can provide a critical link between the control system and the mechanical seed and fertilizer distribution mechanism. This seeding system, often ground-driven from the wheels of the implement, maintains seed and fertilizer placement accuracy even when the ground speed of the equipment changes.
Outstanding Zero-Max VRT features:
•Infinitely adjustable to obtain the exact desired ratio.
•Ratio can be adjusted when idle or when running.
•Easily, quickly, and precisely make speed adjustments.
•Variable ratio or fixed ratio operation.
•Speed and torque capabilities are expandable by the use of chain and sprocket ratios at the VRT shafts.
Applications include air seeders, plot seeders, grass seeding, air carts, research plots, cover crop planting, turf care, and more.
Encased in a secure heavy-duty housing, the VRT resists dirt and debris, is pre-lubricated, and withstands the harshest environments and climates. It is designed for reliable operation with minimal or no maintenance.
Available in two sizes, each offering 0-300 rpm input speed and a 0 to 0.25:1 ratio range of output to input speed. The VRT-150 is rated for 150 in-lbs torque value with the VRT-300 rated for 300 in-lbs. Both sizes are available with input and output shafts on the same side or opposite sides of the housing, with output shaft rotation in clockwise or counter-clockwise direction and with a variety of control options. Special designs are available.
Zero-Max
www.zero-max.com
Filed Under: Automotive
Tagged With: Zero-Max
