    • Subscribe!
Zero Surge ‘FF1 Series’ filters have branch circuit surge protection
By Natasha Townsend | July 13, 2012
Zero Surge Inc. “FF1 Series” surge suppression for commercial and industrial applications integrate a patented filter system unlike others to provide unprecedented protection for one or multiple branch circuits.  Using Spectrum WVR® (Wide Voltage Range) filter technology, the surges sense and suppress power line surges whether the power is low at 85 V, high at 175 V, or anywhere in between.  The filters further protect against noise damage by removing EMI/RFI disturbances from the power line.  Applications include whole rooms, entire 20 A branch circuits, and sensitive electronics.
FF1 Series surge filters have never experienced any surge-related failures, fires, downtime, or recalls.  Certified by the UL® Adjunct Classification Program, the surges have the capability to endure 1,000 worst-case without degradation or failure. All units are triple tested on computerized test systems as part of a rigorous quality assurance program.
Standard models include the FF1-8W-120 (8 A capacity for 120 V applications), FF1-20W-120 (20 A capacity for 120 V applications), and FF1-20W-240U (20 A capacity for 120/240 V applications).  All units are housed in NEMA 1 enclosures with a screw cover and do not require the usual supplemental point-of-use products.  Euro connectors are available for simplified wiring and the 20 A versions can be supplied with flush covers for recessed mounting.  Custom solutions can be developed to satisfy particular application requirements.
Zero Surge Inc. manufactures USA-made non-degrading panel mount, plug-in, and OEM power quality filters that suppress worst-case surges and perform EMI/RFI power line conditioning.  The products eliminate the surge damage and equipment loss often experienced with sacrificial metal oxide varistor (MOV) type surge suppressors.
Zero Surge
www.ZeroSurge.com
Power Supply Tips
Filed Under: Power Electronic Tips, Surge protection
Tagged With: Zero Surge
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
    • Subscribe!
